which turbo for my 420a project??
scottdsm4g63t
32
Dec 1, 2011
quincy, Illinois
My original plan was to throw a hx35 on my car but from some research people are saying it spools just the same if not slower then a .70 t3 which is what my friend is trying to sell me for 50bucks. i just wanna know what turbo will be good for spooling 30psi and begining spool around 2500-3000 rpms. :banghead:
30psi! Well everything is possible. You have to let us know what you have for internals, because if you have stock internals there's no way you will be able to do this. But a evo 3 16g will give you close to what you want.
The small 16g is definitely the way to go. For roughly 9psi in the most general case the compressor wheel itself has a thermal efficiency between 70% and 75%, one of the most efficient compressor wheels that MHI offered during its production (in the range that I assume you are looking at).
I would stick an especially small turbo to compensate for low boost. I would say any of the 16g turbo models would be sufficient. an HX35 at 30psi would outlive your engine very quickly. LOL.
Any 16g in a nice 10cm t3 housing. I just built one for my friends Turbo probe project I'm not sure what to expect honestly but his goal is controllable spool for traction and 300 HP. We expect spool around 3200 its a big 16. For a total investment of 200 its worth a shot and that's rebuit.
Can someone post up a picure of an evo 3 16g turbo bolted to a 420a head.
:hmm: If memory serves me correctly, from reading threads the 2g cast turbo manifold will not fit on a 420a.
So, without a custom turbo manifold fabricated, the evo3 16g Big or small will not work on the 420a.
You are right on the evo 16g turbo, the turbo I don't think it will bolt right up with out modifications. Normally the cheap cast 420a turbo manifolds are t3 flange but you can always buy a tubular with dsm flange or make one. When I had my 420a I always though about using the 4g63 tubular manifold and cut the flange the goes to the head and replaced with the with one that fits the 420a head, like the flange that are on cheap ss header on eBay.
Some more details about your goals for the car would help quite a bit. How much power are you hoping to make @ 30psi?
What do you plan to do for supporting hardware to run an HX35 sized compressor at that pressure ratio?
If you do go that route, I would suggest you have someone fab you up a divided t3 manifold and use one of the stock holset turbine housings.
And it's not clear what you mean by:
Because BEP offers a T3 .70A/R turbine housing for the HX35.
If you decide to go smaller, I would side with the guy who recommended the Small 16G, or a 16G in a larger turbine housing.
I did a 95 gs to gst conversion and i had to custom build a manifold since a buaght manifold and turbo set out to close to the radiator fan and melted it and cuaght fire. Good look tho. I always love seeing conversions. You just know that people put more work then already starting from a turbo platform. And also cheaper insurance ;)
Since the 420A faces the opposite direction, this would be a decent application for an EVO VIII/IX turbo. Which makes packaging a bit easier Have a manifold modded with the correct flange and you'll be good to go. Tuning is/will be an issue though. Mega Squirt is pretty well sorted out for the N/A cars. That turbo will provide more than enough oomph for you.
i have a slimmer radiator in there now causi thought clearance would be an issue with a turbo sticking off my manifold
and on my internals im running weisico 8:5:1 .20 over pistons with eagle h beam rods, reman resurfaced crank, the head has crower stage 2 turbo cams with 6 angle titanium valves, guy at shop said its built to same specifications as stage 5 head, arp main and head studs. i want 400+ out of her and the cylinders are sleeved also
GODSPEED T3T4 TURBO CHARGER .57 trim (polished housing) | eBay
Something like this but mine is a garret. T3 t4. 5 bolt exhuast o2 flange. 3in inlet 2 in outlet cold side. Hot side has the 4 bolt inlet flange. Im not sure if it will hook up to a 1st or 2nd gen stock exhuast manifold becuase the only manifold ive had for it to go on is an xspower i beleive is what it is called.
