Which style of gauge?
GSX Eclipse
239
Oct 9, 2006
Coal Center, Pennsylvania
So I'm ordering my gauges for my car and I can't decide on the digital or analog wideband gauge. The analog would go nicely with my other 2 gauges but the digital gives a precise readout of the air/fuel.
What would you go with? Below are the links to the two gauges I already have. The third and fourth links are of the analog and digital wideband.
Elite 10 Color Oil Pressure Gauge
Black 7 Color 30 PSI Boost / Vacuum Boost Gauge
Elite 10 Color Series Wideband Air Fuel Gauge
Black 7 Series Digital Wideband Air Fuel Gauge
Thanks for all the replies, I decided to go with the digital. I have to stick with the glowshift brand because I have money towards them with some gauges I returned. I haven't heard anything bad about them so stay tuned for some reviews with the wideband when I get DSMLink v3 lite!:thumb:
Let us know how you like the glowshift. I am getting ready to purchase as well and feel the same as you. I would love to hear pros/cons.
Sent from my Droid Incredible using Tapatalk.
Well I had the boost gauge and 100psi oil press gauge installed then a few hours later my car underwent a plague of problems, alternator going bad caused by being soaked in oil, oil drain bolt coming loose, and a mysterious oil leak. (I posted a thread here but it seems people stopped responding?http://www.dsmtuners.com/forums/cylinder-head-short-block/386242-95-tsi-low-oil-pressure.html)
But since my oil pressure was low it never went above 100psi so the oil gauge worked well, I bought a sandwich adapter from glowshift to put between the oil cooler and the oil filter, had some clearance issues with the dp but the fat and short 1g I think it is oil filter solved that problem. The boost gauge worked with no problems whatsoever. I'm in the process of exchanging some gauges and their customer service is great! The boost gauge is still working good, even though my car hasnt seen the road since August.
I decided to go with a digital wideband from glowshift. I'll post a review of them once they stop salting the roads around here. LOL
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
