which plug for turbo nitrous?
NeDSM
37
Feb 18, 2004
Lincoln, Nebraska
I have a turbo (14b @16psi) and a dry (ZEX 55 shot), i need new plugs, i was told to get BKR7`s, ive found BKR7E, BKR7EKC-N, BKR7EKU, and BKR7ES-11, whats the difference? and which ones should i get? i know i want copper plugs and i want plugs a step colder then the stock 6es, and also to gap them .005 tighter then normal. is this all correct?
they all measure the same and they all will fit, however, the BKR7EKC-N has 2 ground electrodes, and so does the BKR7EKU. The only difference between the two is the BKR7EKC-N has a longer projected tip. I use the BKR7E-11, and you asked about the BKR7ES-11, the only difference is the BKR7E-11 is V-Power to prevent quenching of the spark. If you decide to get the BKR7E-11, don't get the one with the S, cause it's non V-Power, and you don't want quenching.
i really don't see the point in 2 ground electrodes, because using nitrous you will go through spark plugs quickly anyways. i mean, they have those rediculous 4 electrode plugs, lets start a spark plug company and make 10 electrode spark plugs. I think you're better off with the BKR7E-11, solid plug.
Hope that helps :rolleyes:
thanks, that does help, where can i find the bkr7e-11 plugs?
from NGK.com
keep in mind, they are NOT ngk, but a distributor for them. i've been ordering from them for years though. good site. goto their website, and either type in 1283 or BKR7E-11 in the part number box. $2.24 a piece.
http://ngk.com/
i use bpr8es with my zex 75 dry shot and 14b @20 psi with a supra sidemount. i like those plugs for this combo
