Which parts fit in a Colt 92 200GT? Help.
YuGr
Sep 24, 2009
Montreal, QC, Canada
Hey guys im new to the forum and the DSM world. I was thinking of a little side project I would do which would consist of getting a 4G63T block in my Dodge Colt 92 200GT. And I was simply wondering a couple questions in terms of which DSM parts I should be looking for (Such as 2G DSM parts, 1G dsm parts etc..) I searched the forum and have not seen any related post to this, perhaps I am misplaced on this website although I took a look around and I quite like it.
So here's the quesiton: 4G63T (only 1G will fit right?) in a colt 92 200GT how easily will it fit? Will I need the harness from another DSM if so which one? Any 1G DSM's ?
And 2nd question is in terms of parts such as FMIC and 16G turbo kits (I'm mostly asking for the pipings) how will I know which one(s) will fit in a colt with the 4G63T in it? Basically, does it have the same or very similar engine bay to any other 1G DSM cars? So for example if I'm looking for a FMIC on this website and I see some f/s for 1G DSM's will it fit with a dodge colt?
Thanks a lot guys any help is much appreciated. I've been looking through other forums and have not found a clear answer yet.
You might want to look over at mirageforums.net . I'm not totally familiar with the 200GT but that swap is fairly common. I swapped a 4G63T into my 4G Mirage and used the following from the Talon I stripped
Intercooler with piping (the stock piping fit, I just shortened some pieces and did some trimming on the Mirage)
FWD Exhaust (modified some hangers and made a new section to go over the rear axle)
Fuel pump (almost a direct bolt on)
Complete wiring harness (I swapped every harness except the rear)
The 2G DSM engine mount was a direct bolt on
All Talon accessories
I used the Mirage transmission which is an F5M22 with the hydraulic clutch.
I don't know if you've tried Mirage Turbo/Colt GT • Index page but there is a lot of info there. Between 4G61t and Mirageforums I have all the info I need to do my own swap,when I'm done gathering all the parts(and I need a car LOL).
Is the GT turbo,or is that the GTX? If it's a GTX a 1990 motor will swap right in,if it's not you need the same year wiring harness and motor,and Hyundai Elantra motor mounts(I believe one of them is modified) and a DSM fwd tranny
