which oil passage?
spaceball
79
Jan 19, 2004
wakefield, Massachusetts
i just installed the balance shaft removal kit and i want to be sure oil pressure is getting to the head. the head is off the block and oil is in the pan. when i run the oil pump with a drill oil only seems to come up through the small hole on the front passenger side corner of the block. so my question is which oil holes through the deck should have pressure? :confused:
please! someone here has to know. which oil passages feed the head and which ones drain from it?
[Only oafish, inconsiderate, non-thinking drillheads cross-post. You're not one of those, are you?]
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
