which middle timing cover to use
nastyleak
93
Oct 14, 2010
Mobile, Alabama
Using a later year (98-99) block in my 95 Talon reusing accessories bolts etc. from 95 block which middle timing cover should I use? I can't seem to find what the difference is and don't want to get the wrong one. Also using all new timing parts, oil pump, water pump etc.
If you are using the 95-96 cam sensor that us behind the cam sensor than use the 95-96 middle cover. The 97-99 cover doesn't have the hole for the harness to go thru.
