Which A/C Condenser to perchase...
Personally, I would go with the cheapest. None of the others are Mitsubishi OE anyway. As long as a warranty exists, you should be fine. I don't know what their warranty period is but, I see they offer extended warranties.
Yeah this is what I was leaning towards as well. Thanks, appreciate it.
Which one did you end up getting? The Silla brand has two models; one is for R-12 and the other is for R-134a. I thought all 1G cars ran R-12??
I'm in need of a condenser, also. Advanced Auto Parts sells the Visteon brand, the Ford OEM supplier, and I'm debating between it and the Silla brand, since Mitsubishi OEM is no longer available.
Are you still running R-12 or did you convert to R-134a?
Also, you should replace the receiver/ drier and seals for it and the condenser while you're at it.
  • Wanted 6 bolt NT water pipe
    • chrisman287
