Where to tap for methanol injection boost switch
overboosted1g
743
6
Jan 13, 2010
washington, Michigan
So I'm in the process of installing my methanol injection setup and I need to know which port on my tb that I can hook the boost switch up to. I don't wanna tap into my fpr because my boost gauge is already spliced into it.
Sent from my HERO200 using Tapatalk
T in with your FPR and boost gauge, it would be wise to make sure all 3 things are seeing the same thing. Unless you have a leak some where in the 3 lines using 1 port for the FPR, gauge and meth will not create any issues.
PS if you are using a mechanical boost gauge be sure to run a rubber or sylicone hose vs the small hard/stiff clear hose many gauges come with. (prone to cracking very quickly)
