where to plug egt sensor in at?
Drive pressure and EGT are both on runner #4, drive is the bung with the SS line plumbed to it on the left and EGT is the open bung by the cam gears on the right.
I also have a post-turbine EGT ahead of both O2 sensors.
^WTF WTF! -LOL. Where does the exhaust go!?
Here
Edit: There is minimum ~3/8" gap between the pipes across the whole run, I can also use a small band of heat wrap and snug them together.
The rule of thumb is 2"-4" from the cylinder heat port. That is where we run ours. We run all four cylinders though. Best data you can have for your engine. We have been running a hood exit exhaust for some time and have never had any soot issues.
Thanks for the clarification :thumb:
I would add the exhaust flapper like the semi-trucks if I had that setup -LOL, jk.
Thanks guys!!! I'm going to try to tap into the number 4, thanks for all the help guys. Landspeed you have one hell of a setup... Let me guess daily driver!!! LOL!!
I've thought about it! But I would have to make some unsightly notched holes in the hood to clear them.
Thank you, she will see street duty!
