where to connect tow strap
gijoe985
562
20
Dec 13, 2007
Grandview, Washington
Where do you connect a tow strap on a 90 talon awd? I only need to go a short distance so I figured go 4 wheels on the ground.
I was trying to search for an answer once I typed in a title, but I accidentally posted it, so I went back to fill it in...
Thanks
There are tow hooks to the left and right of the radiator underneath. Pop your head under and you'll see them.
Yes the safest way would be to use the shipping hooks on both sides of the core support, I honestly don't recomend moving your car that way(I drive tow truck), I have seen it cause more damage than good. My opinion would to move it with all wheels off the ground, definatly do NOT have it moved with a regular wrecker though, and good luck with moving it.
