1G Where to buy center diff bearings?
91stocker
3,623
80
Jan 15, 2010
Vassar, Michigan
I trashed the bearing on the outer gear pulling the center diff out. Does anyone stock these anymore? Or does anyone have the part numbers? The numbers i found seem to not exist anymore LOL. Also need the output shaft retainer.
I'm guessing this is probably a bearing that doesn't cross reference with some super common and cheap bearing by chance is it?
EDIT: I should have specified this is for an auto.
So i found a part number that crossed with a Mopar bearing for a jeep on some obscure site that had no pictures or prices. Any Chrysler guys know anything about that?
Why not take the bearing out, take it to a parts store, have them bring out the Mopar bearing and compare the two?
Good question haha. Im going to call up there and see if the number matches anything they have.
I was hoping someone knew of a place to get them though. People are getting them somewhere, or is this a shop secret?
I mean taper bearing assemblies are cheap and common. There has to be something that matches.
Is this something that just never gets changed? For as often as these diffs break i would think this would be an easy part to find.
No one has a part number or any info on these?
For future reference Mitsubishi does in fact still stock these bearings.
Front bearing #MD 728354 -$22
Rear bearing #MD 718322 -$56
But the front bearing can be picked up for $9 through various online sites.
The rear bearing cross references with part number SKF32009x and runs $22 online.
Alternate part numbers that came up for the that bearing: 0049818405, 0079816505, 061327305, 1L2Z7025AA, 24903820, 3140880X05, 4393442, 4573737540, 6319800102, 6319810480, 6319810781, 6638131175, 6638131188, 8971183070, 91124PS3008, 94258819, E92Z4221A, F3XY4221A, MD718322
Tapered Bearing Cup & Cone Set
Width (in) 0.7874
Outer Diameter (in) 2.9528
Inner Diameter (in) 1.7717
Cone Length (in) 0.7874
Cone Radius (in) 0.0394
Cup Length (in) 0.6102
Cup Radius (in) 0.0394
The dimensions for anyone who might need it.
I'll be stopping into a chrysler dealer in a bit here to see what they have as one of the part numbers crossed with a bearing set for a couple jeeps and a pacifica. I'll update this thread with any info i find.
