Where this wg hoses go?
Quadsportz
113
Dec 12, 2012
Oak Hill, New York
Took my turbo off last night here a pic of the waste gate hoses. The bottom one in my hand went to the waste gate and the other one was just there. The two hoses are held together with a clip so i would think they would go to the same place.
Here ya go. Stock 2g routing:
i dont get it. Looks like one hose goes from waste gate selenoid to the t fitting where the other go?
Look at the pic again. The short one goess to the intake pipe. The long one goes to a tee fitting that branches off to the compressor housing and the wastegate actuator. Now, both of those lines you pictured come off the boost control solenoid??
1 of them hoses might go to the stock boost controller and your missing a small T with 2 hoses on it, how do you not remember how to put it back together as you only took it Off recently! Haha
Closest nipped to the front of the car
Ok i found where it has to go but there is no way i can fit the hose in that small hole i must be missing something that connects it.
Unless its the one on the opposite side of the pipe, there are 3 connections total on there so it will fit 1 of the 2 small ones
i see two connection on the bov side of intake pipe. one connected to valve cover and one to the emission canister. I only see see connection on the other side of intake and the hose wont fit in there had to be something missing
Ok so you have them connected, good.
You are missing a straight connector which is similer to a T but its straight, they normally dont go missing as there glued in most of the time, so you either find it or buy a straight connector
