4gfun
Supporting VIP
- 2,012
- 56
- Dec 10, 2007
Ask Me,
Virginia
I'd like to add a fuel pressure gauge and a fuel pressure regulator. It is a Galant VR4, so where would the best place to put these items be on a 1g?
Thanks
Thanks
I mounted mine about a foot to the left of my brake booster almost near the center of the firewall. I have a fuel lab fpr and Guage and it fits good and looks nice when the hood is up.
You take your stock fpr out and ad on an adapter to fit whatever size hose comes with the for.
Im pretty sure the FPR goes on after the fuel rail. So filter, rail, then FPR, then return line. The gauge can go where you want it. People have it right at the begining of the fuel rail or mounted on the FPR itself. The stock regulator goes in thee trash once you're installing a AFPR.
Thanks, so the stock FPR is on the fuel rail at the end of the rail towards the passenger side of the vehicle if I have this right?
How can it go on after the rail if the rail is where the fuel ends? WTF
Not sure on a GVR4 but whatever way the fuel travels then it should be on the end right before the return fuel line.
It needs to regulate the pressure inside the fuel rail so the injectors would have a constant pressure at all times.
So after the fuel enters the fuel rail where does it go? The fuel rail is the last place fuel goes before it hit's the injectors and enters the combustion chamber. So the AFPR has to be installed before the fuel rail not after.
Use a hose, silly.
But seriously, the fuel doesn't end at the rail. The excess fuel shed by the regulator is sent through a return line to the fuel tank.
your guage would have to be before regulator so you still need a adaptor or a t before the rail . yes it would work and tell you weather your getting the right pressure at wot .. classy move figuring out how to work duct tap in your fix !!!!!
Lol, no class here!
Wouldn't I still be better off with that fancy pants setup when it comes to raw diagnosis though?
I don't want to miss out on anything by not viewing fuel pressure at the end of the rail.
If I don't check pressure at the end, I could still have a screwed up regulator and not see it right? Also possibly miss a few other potential problems no?
Just asking while all you brains are here!
your line pressure and rail pressure will be the same before regulator you will miss nothing noticeable.
Will it tell me if my fuel pressure regulator is bad if I locate it there?
I need to read up on how fuel pressure regulators work but wanted to ask you that before you disappeared into the Matrix.
Thanks
Thanks
If you're looking for the diagnosis aspect (i.e. to keep an eye on whether or not your fuel pressure is rising 1:1 with your boost) just get a remote fuel sender for your fuel pressure gauge and mount it inside your car. The placement of your gauge needs to be before the regulator. Currently I'm running mine on top of my fuel filter with a M12x1.25 banjo bolt with a 1/8NPT fitting screwed into the top. Fuel pressure regulator will ALWAYS be AFTER the rail...no questions asked. If you mount the gauge on the regulator itself, it is STILL considered before the regulator because it is picking up pressure readings before the actual mechanism that controls the pressure within the regulator. It will work this way whether you have a fitting on the rail exit with a line going to the regulator mounted on the firewall, or if you have the regulator mounted directly onto the rail as I do.
What do you mean if your regulator is bad? If it's bad it won't hold your fuel pressure with any consistency and/or it's being overran. If you mount it on or before the regulator, yes it will show this.
yes or if your fuel pump is weak also if you have not yet done it you might want to do fuel pump rewire.
