where is the starter solienoid?
Royalty
904
Apr 30, 2004
norfolk, Virginia
i think this may be the root of my problem, also when i fnd it where do i get replacemnt solendiods?
Mounted on the starter. Did you check the ground like I said in the other thread?
Here's my post in your other thread.
You said....
not yet. i can turn on my headlights, fan and what not so would i need to check my ground?
I said....
Because your starter requires ALOT more power then all of those combined. Trust me, go check it. If you don't want to then have fun changing out eleventy billion starters and still have the same problem.
Chekc BOTH grounding cables that run off the battery. Remove them, clean the cable itself and the surface it mounts to
Defiant said:
This ain't no damned Ford, the solenoid is on the starter. You don't replace them by themselves, but unlike a Ford, you'd never need to.
haha thats a good one. i used to work at a ford dealership and i would never own one. hahah
