Where Is The Rear Motor Mount On The 420a?
bo0st
835
24
Jan 26, 2010
Phoenix, Arizona
Where Is The Rear Motor Mount On The 420a? I had no problem finding and changing the one on the left, lower front and this one (19)
attachment.php
I can't for the life of me find the last one. It looks like this:
You had no problem finding the one on the left huh? LOL
It's on the subframe. Your pic is of the drivers side, stand on that side of the fender and look down towards the back of the transmission and you'll see it. The bracket that the bolt goes through the mount is attached to the transmission.
You're welcome again. LOL
Its on the rear.
That's not very descriptive. Do you have a picture?
I don't think you know which mount I mean. I already replaced the front roll stopper. Got a pic bro?
I'd appreciate a picture and not several "LOL's" yeah I know, it's funny I can't find a motor mount. We were all once newbies guys c'mon help a brother out.
This is an actual picture of a 99 GS that I own that had an automatic transmission in it which you could see the engine and transmission I pulled previously.
The rear mount is on what is commonly called the "subframe", MITSU calls it an "engine cradle" or "crossmember". Look at the center of this picture and below the yellow piece of paper and that is the rear mount. It's pretty much in the middle but more towards the drivers side.
The front mount is attached to the "support" bar.
Both of these mounts the brackets that they sit in are attached to the transmission.
Here is a picture of the engine and transmission removed, look at the transmission and you'll see the front and rear mount brackets and on top of the transmission is the plate where the drivers side mount bolts onto.
You should be good to go now.:thumb:
I thought the rear was a roll stop? I got the prothane mounts. They look sweet. :D
