where is the crank angle sensor on a 2g
xdrugxfreex
Apr 9, 2008
west jordan, Utah
i am putting on a 1g head and trying to find how to wire in the cas and i read a site that said you need to wire in the crank sensor too so i was wondering where it was located thanks
I've searched around the forums and I'm having a hard time finding the answer I'm looking for.
I have a 97 Eclipse GST and the CAS is on the passenger side (which I've been told I can use to adjust timing) and I'm fixing to do a swap with an engine out of a 96 and the CAS is on the other side behind the cam gear. What I'm trying to figure out, is how do I switch that 96 engine so that the CAS is on the passenger side instead of the drivers side?
I had a friend of mine try to explain it to me, but for some reason it just confused the hell out of me.
I've searched through the forums once again, and I'm still coming up with nothing. Can anyone point me to a tech article or share some first hand knowledge on how to swap the CAS so that I can adjust timing on a 96 7 bolt?
