where is my brake fluid going?
Mits3gts
188
Sep 30, 2004
bellingham, Massachusetts
i have to fill my brake fluid every other day.i have looked everywhere for leaks and i cant find one drop of fluid.i followed all the lines and removed the tires to check all in there and cannot find any leaks....does brake fluid evaporate quickly? thats the only thing i can think of.
It must be leaking somewhere because it's not disappearing. If the brake fluid was coming out of the lines on the calipers, you would probably notice a clean spot or some kind of streak under or around the bolts that hold the cables to the calipers. You should keep looking because there's probably a leak somewhere that you just haven't noticed.
