Where is my blowby coming from?
Kyle97turbo
47
Dec 15, 2005
Omaha, Nebraska
I am getting some pretty bad blowby heard through the valve cover when I do a boost leak test. I disabled the pcv to rule that out and was still getting the blowby. Could a leaky compressor seal on the turbo be causing any of this? Its an evo3 16g that I just rebuilt. If not whats some other possible areas I should start looking at?
Put a wrench on the crank and turn it clockwise until it no longer leaks, you probably have intake valves open still, allowing air to rush through the motor.
Even if the valves are fully open it shouldn't pressurize the crankcase. Hopefully it's just a bad turbo seal.
Yeah I will be doing a blt from the throttle body tonight to check if its the turbo. After that ill try the comp test and leakdown test. Compression should be fine it was 170 on all four just a few weeks ago and I haven't really drove it since then. Hoping for bad turbo. Also doesn't burn any oil or use any coolant.
