where does this line go..
tek9
71
Aug 18, 2006
alexandria, Kentucky
Hey guys, sorry but i couldnt find out where the hell this line goes, its a 6bolt engine, its the cylinder/? that mounts onto the transmission (right next to the gear lines, manual transmission) , i cannot figure out where the other end of the line goes.. please help! :]
Can't see a pic but it sounds like your talking about the slave cylinder for the clutch. There should be a metal line the bends and screws into a fitting that goes into a rubber hose, and where the two meet there should be a bracket that bolts to the inside of the engine compartment.
Hope that helps.
I'm pretty sure you're talking about the slave cylinder. If your talking about the hose coming out the top of the cylinder then that curves downward and then makes it's way towards your oil pump and stops at the bleed valve just past your frame member.
If you're talking about the hose coming out of the side, then that one goes towards your fender and then back down and curves towards your firewall. Then from there it makes it's way to your master cylinder near your clutch fluid resivoir.
hey, some reason the picture didnt post, here it is though
Here i hope these help...
The first pic is where the line is routed from the top of the slave cylinder and how it's routed down out of the way of the shifter and the second picture is where it's connect to the bleed valve just in front of the fly wheel (i know i need the inspection cover :()
