The where does this line go game
toppertopper
444
May 14, 2009
edmonton, AB, Canada
my one problem ..I Don't know where a couple lines go on mine so i have no boost atm
Pics are of the 2 lines on the bsc not sure where they go :confused:
Pics wont upload ...See 2nd post of mine LOL
possible chance you didn't put a gasket back in and that could be causing an exhaust leak. check and make sure all your gaskets are there.
You would be hearing it SO loud if it was leaking preturbo bad enough not to spool up LOL. It would be quite obvious. Damn, so your wastegate is good? Or did you test it at all?
Other than that, everythings been covered: IC piping or bad turbo. Theres really only 3 things that can cause this.
i bought my talon with a leak at the turbo and the manifold, in addition it had a loose bov and yet i was still able to spool roughly to 15 psi...if thats the issue you have a helluva leak...i can agree with the earlier replies to the wastegate being a possible issue or perhaps blockage in manifold before turbo perhaps??
You know i just thought of something i read on here a while back lurking: an exhaust blockage AFTER the turbo could possibly cause this. Like a collapsed flex section or clogged cat. Another idea i thought id share. Sorry if im posting too much but i just remembered it and hoped i could help.
It was the manifold ..It was dark last night ..Bolted it down and bammm ,spooled up nice ..Now i can rip it all back apart and start on the mods :)
Thanks again everyone
