2G Where can I get a rear AWD wheel bearing and hub assembly?
jwilt2008
111
Apr 25, 2010
Novi, Michigan
I need helping finding rear wheel bearing and hub Assembly for my 1995 talon AWD. Every place i try is sold out or they have one that looks likes this and im pretty sure thats not the one i need. Any help would be nice or maybe someone has a used good one laying around that they would like to sell. this is the only one i can find around me and it does not look like the right one
Timken/Wheel Bearing/Hub Assembly - Rear | Wheel Bearing/Hub Assembly - Rear | 1995 Eagle Talon 4 Cylinders F 2.0L MFI Turbo DOHC | AutoZone.com
Maybe I'm wrong, but I think that's the rear bearing and hub assembly for a FWD. I believe the AWD rear bearing and hub assembly is:
That if I remember right when I was searching for them in October. Also if you are wondering about other places that sell OEM parts. I know www.JNZtuning.com does:
JNZ Tuning Online- OEM Mitsubishi Parts
there is a link. They are one of the forum vendors, and specialize in are OEM parts. I'm sure you can call them and they could clarify things for you, but I am 95% sure that first link I gave you is the proper one if I remember right.
hope that helps!
Thanks Yeah i thought that first link was the right one also so i ordered it and i just got a email saying the vendor is out of stock so they really dont have it. I really want the whole assembly but is there a part i can get without the whole assembly?
Have you gotten the hub off of the car yet, and have you separated the hub from the drive shaft and then separated the bearing from the hub? LOL
Also did you get the bearing or did you get the hub with the bearing? You can get a bearing on its own but you can't get a hub on its own :confused: so if you can't get them apart you will be buying twice.
Why I'm asking is I've just started doing mine as I'm rebuilding the rear end of my car and it took allot of effort to get the hub off of the knuckle (I found a real good way of doing this)
Then I had to take the whole hub and wheel bearing with the CV joint still all attached to each other along to a garage, they got one side apart but even with a 25ton press they could not separate the other Hub :hmm:.
Just letting you know what you could be in for ;)
I have not started it yet but the part i got has the whole hub assembly with studs and all so should be bolt off bolt on im hoping. LOL
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
