Where can i buy stock replacement camshafts?
ktyr5151
92
Feb 21, 2011
cavendish, Vermont
Like the title says... Im looking to buy some replacement camshafts or atleast something close to them? Anybody know where I would be able to find some? I would like to stay away from used if possible. But Mabe something with a little bit more aggressive than stock... I dont know what that would be though.
Thanks.
Go with the comp cams 264's. They are slightly more aggressive than stock, very streetable, and cost way less than the hks' but still give you the great quality. May I ask why you are looking to do a cam swap in the first place?
I brought my car to the shop to get the headgasket put in and the mechanic said my exhaust cam was in pretty bad condition. So i figured i might as well change both the exhaust and intake cam.
Good call, you might as well put em in if you have the head off. Stick with the 264's though, no matter what brand you go with. Are you also doing adjustable cam gears and/or timing belt?
Why would he have to stick the the 264's? and why would he need ADJ cam gears? Good call on the belt though, minus well replace it now while its apart. :thumb:
cant beat a price that SIM offers so props to them. if it was me i would get their 264/272, cheap plus power gains is like double dippin.
If he doesn't want to upgrade we have a stack of OEM cams at the shop. Let us know either route you take.
So i got a call from the shop that my car is at and he said my head is junk. Its to warped to mill down. So im now in the market to buy a 6 bolt head. Anybody have one?Needs to be complete.
Update: Found a head. Thanks everybody though.
