Where Can I buy ARP EVO Exhaust Mani to Turbo Bolts?
fergulus
205
Dec 18, 2007
Portsmouth, UK, Europe
I found a set of ARP bolts that were for an EVO exhaust manifold a while back on a website, but cannot find them anymore. I have an FP Race Manifold and MAPerformance never shipped me all the correct bolts, so I am missing one. I want to go ahead and get all ARP bolts, which were 12pt black coated.
Does anyone have any clue where I can get these? I have tried all the big companies, i.e. MAPerformance, Slowboy, JNZ, STM.
Do not use arp bolts for the turbo to mani many people have had them sieze in there and snap when trying to remove them. Get OEM bolts with 2 oem turbo lock washers per bolt and you will be set.
I agree, I also recommend not to use the arp bolts for the turbo to exhaust manifold.
FFWD Connection - Race Injuns That Will Freeze Your Brain
As far as the trend of saying that ARP bolts break off more than OEM, I currently am running SS ARP turbo bolts on a MHI turbo with absolutely no issues. They have not loosened up or siezed as I have seen in other threads.
The bolts that I was looking for, and I posted a link to, are not the stainless steel bolts that one person had issues with loosening on this site.
Thats correct. Those are the bolts you want. I am currently running those with no issues. Make sure that you have a new gasket, and that you get that broken bolt out so you will use all four points. Without that you stand a great chance of never getting a good seal and having an exhaust leak. That means less power.
The stainless steel bolts that I HAD in my manifold actually warped. While they never loosened under driving or vibration, one was so bent that I could not pull it out of the manifold at all.
Like that never happens with the OEM bolts. Plus there is only one person who has has had a problem like that with ARPs and they were stainless, not the chromoly bolts. I will be using the ARP's from FFWD on my turbo swap.
