wheels inward on top and stick out on bottom????
1998greyeclipse
Jun 12, 2009
Liberal, Kansas
I have a 98 eclipse and the wheel on my car seem to slope in ward if you look at it from the back?? I havent changed the springs or the struts would that be the problem?? also I have this klaking sound on the driver front tire when i change the strut the sound quiets down. I have changed the strut twice already.:ohdamn:
The tires tilting in would be camber, yes camber kit would fix this. As for the sounds, have you checked all the bolts and strut top for damage/wear?
yes I have checked and everything seems fine would I need to change my coil in the driver front
Also would I have to replace my struts and coils because of the hight of the rear end of the car???
Just go get an alignment and that should give you a good idea of weather or not you need a camber kit. Just ask the guy about what everything is set to after hes done
