Whats the A/R on the turbo mean?
A/R = Area to Radius Ratio. I'm looking for a picture of it because it's easier to explain with a photo than it is in words.
EDIT: Here we go.
The turbine housing A/R (area/radius) ratio is the area (A) of any turbine inlet scroll cross-section divided by the distance from the center of that cross-section to the center of the turbine shaft (R). For any given turbine housing, A and R vary in the same proportions, so all As divided by their corresponding Rs yield the same dividend--which is the A/R ratio.
just one little note to add, this then means that a larger A/R increases lag, but overall flow and therefore boost, as less of the air is then forced out the wastegate.
Trim if i remember correctly, is ((exducer)/(inducer))^2 * 100. I may have those inverted, but thats your trim. Its a ratio of your impeller wheels. Trim will be a bit more helpful in telling you what your spool and overall boost will be, although it wont actually tell you this, just give you a general idea, something i dont think you can get from just an A/R (someone correct me if i'm wrong here).
    • george bromwell
    • pma1123
    • Sdcryan1
