Whats best for my goals?
praisethelowered
Jul 7, 2016
saint george, Utah
Hey guys haven't posted in a while but would like to ask what set up would be best for me personally? I know there is a lot of other posts on what others have done but I'd like to see what would be best for me.
Goals: 300-400whp, retain Ac and heat, retain the fog lights, daily driver.
Budget: Around $5,000
My car and its mods: 98 GSX, Stock t25, stock blow off, full turbo back 3 in exhaust, k&n filter, and coilovers.
Just bought the following - Drilled and Slotted Rotors front and rear, 3 Prosport evo Premium gauges (boost, wideband, and oil pressure) 3 gauge pod for pillar, and a Hallman Manual boost controller.
So what do you guys think? Which turbo, BOV, Install kit, front mount, injectors, etc? I know i'll need dsm link and am looking for it currently.
I can give you the same answer everyone else will. Maintenance first, then dsmlink, a crushed 1g bov would work. And a e316g would get you there. You will also need a rewired 255 and some injectors, probably 750s would plenty for pump. Condensed version but it's the basics.
Definitely DO ALL MAINTENANCE FIRST! That is the most important thing you can do for the car before you throw another 100+ hp at it. You want to keep it healthy so you can enjoy it:)
You can get it done for way less than $5000 if you get good use from the classfields here, just remember to take your time and do everything right the first time!
