Whats a good EGT temp?
endlessMyk
791
4
May 3, 2004
State College, Pennsylvania
I tried searching for this and just found a lot of debate on wether egts are worth it. Well I have one, and just wondering what kinda temps would be considered "normal" Here are my mods: Ported 1g Exhaust Manifold
7cm turbine housing upgrade
2.5" ported o2 housing
2.5" downpipe
3" hi flo cat
3" cat-back
lucas 550cc injectors
apexi s-afc
walbro 190lph fuel pump
2g throttle body elbow
2.25" uicp
K&N Filter
magnecore wires
ngk plugs
SRP mbc set @ 18psi
ACT2100 clutch
american racing 16" wheels
apex 1.8" lowering springs
clear corners and smoked tail lights
autometer boost, a/f gauge, and EGT gauges
SOrry if this is a repost, i just couldn't find a thread that said the best #s
After my car warms up, i idle at about 1000F. When cruising its usually about 1300 to 1350 at around 60mph or so. When i floor it, i just make sure it never goes over 1600. This number can obviously be biased based on timing settings which could easily raise the temperature. Not to mention i know im running a little leaner than some.
Its worth to have one IMO. You cannot tune by it, but its a great backup for daily driving. Mine is usually near 1000* at idle and you never want to go over 1600*. Once you get near 1600*, your probably knocking at that point anyways.
badboyr66, what is the point in mounting it after the turbo? What number(s) do you look for when it is mounted there?
I guess for people scared about the tip of the probe breaking off. Also, I think the issue is just establishing a baseline temp at that location and looking for any significant changes (as opposed to making sure EGT's stay belo 1600)
Actually, after the turbo temps can be up to 250-300 degrees lower. Thats all. Bearing that in mine when tuning you will be fine
mine is tapped on the exhaust manifold, usually when i'm running it, i see it around 1400, and yeah i pretty much use it as i guide that when i'm around 15/16 i let off it.
From what I can remeber. A Aluminum will start melting around 1,400 degrees. I could be wrong. But I feel 900 degrees is damn good for a street car
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
