what wire is constant power? (tap into for gauges)
ApexVIII
812
5
Jan 12, 2008
Modesto, California
what wire can i tap into for the constant power supply for my glowshif gauges?
Thanks guys!
:dsm:
:thumb::shhh::talon:for the power? if so i just tapped my cig lighter but you can tap the cd player or run it with a fuse straight to the battery
:shhh::talon:or for it to turn on when your lights come on the headlights and running lights work great too
if you want it to light up when the car turns on wire it to the radio. or whent he running lamps are on wire it to the dimmer switch.
yea, these are the color changing gauges, so there is 2 power wires, one when i want them to light up(i got it hooked up)
and another power that need a power supply the whole time, to remember the color of the gauges i set them to
so the cig lighter always has power?
Thanks guys!
yea it should but you can also stick a fuse on it an run it straight to the battery
or you cd player has a mem wire it should be yellow that keeps constant power too
hmm, the cd player is alot easyer tehn going all the way to the battery, so ima do that
Thanks alot man!
:dsm:
