What Spark Plug gos to what wire?
Jacie
49
Oct 3, 2008
North Ridgeville, Ohio
Alright, i have a 4g63 and my buddy being a dumb ass took the plugs and wires all out right before I was going to change them, and when I do it I usually do it all in order. Does someone have a pictures of where what wire plugs into what spot? Thx
The order of the cylinders from the timing cover to the left are 1-2-3-4 and on the coil pack from left to right is 4-1-2-3.
Thx, that's weird how that's like that.
Ya it is kinda confusing. You have a 97 so you have to flip it kinda.. the 97 is 1-3-4-2 but our system runs a wasted spark so it fires on the exhaust stroke so its kinda hard to mess it up... And it does have the order on the coil pack... You just read the engine as backwards... left cyl is 4 and right cyl is 1 when looking at it from the front of the car...
Op, I'm not trying to sound like a jerk, but did you try searching at all?
There is a HUGE thread on this, and this is one of the most common problems we hear from "Newbies".
That and idle surge.
Search your problem first next time, then post it to us if you aren't having luck.
Thanks!
All you have to do is run the plug wires according to the arrows on the valve cover and the wires will be in the correct order going up to the coils, so you don't actually ever have to remember the order.
Plus there's actually only two ways to put them since there are only two coils going to 4 cylinders. 1 & 4 are together, and 2 & 3 are together, so swapping the plug wires on the same coil doesn't matter.
