What will fit?
Jonnyktm
37
Dec 22, 2010
Monticello, Utah
I know the Evo has a 4g63, but that it is set up a little different, but what is the same? What parts are swappable? I am looking at buying an Evo and if I can swap my cams and injectors and things then that would be awesome. This may be a good sticky threat.
What can you swap from eclipse to Evo and what can you not? Thanks
Injectors, cams too if you have aftermarket cam gears that have both the evo and dsm dowel pin holes.
Things from the head are swappable..People love to get used valves and stuff and put them as a stock upgrade in the dsm's..
On the evo's everything is on the other side..Where our timing belts, boost piping is,It's opposite on the evo's..
  • Wanted 6 bolt NT water pipe
    • chrisman287
