What Tps will fit?
90gen1tsi
82
Jan 4, 2011
Olympia, Washington
I have a 90 TSI and the TPS is bad. I don't have the 170bucks to spend on a new one. my favorite yard has a couple non turbo ones. Mine is the 4 wire type with the wires as follows. So my question is what other cars can I pull a tps from and have it work? What wiring will I need to change to make one work?
at the connector at the fire wall
black
Green/Black
Green/Red
Green/White
you need the 4 wire tps for yours you cant use an n/a because there only 3 wire, so if you can find any other turbo eclipses/talon/plymoth you can just pull the tps off of those and you would be set, and as for other random cars i have no idea.
  • Wanted 6 bolt NT water pipe
    • chrisman287
