What Wheel Will Fit ? What Offsett ? Helpppppp!!!
Status
Not open for further replies.
1g4g63t
49
Apr 3, 2005
Fort Lauderdale, Florida
so im looking to get a set of 5zigen FNO1R-C Wheels for my 1g.
im either to get them in 17"x8" flat black, 17"x8" bronze 17"x8" silver.
i also want to put 245/45/zr17 tires on them..pretty big width on a 1g but anyways...
what i really want to know is what is the :( OFFSETT :confused: i need to get ? ? this wheel site i put my car info on says to get 35mm offsett but im not sure if that will work w/ 245's...what offsett is required for me to fit 245's ?
also if you guys have any pics of 5zigens on your car post them so i can get a better picture than mental
also give your opinions on what color i should get..check my gallery to see the color and specs of my car..ohh and btw those are pics of the car w/ no motor in it..right now i cant fit my wrist in between the tire and fender..
ok if you want to run 245's you are goin to have to get 245/40/17 because going to a 45 series is tall and might rub. a 40 series is slightly smaller cirumference than stock so it shouldnt rub. As for the offset i have 17x8 w/ 35mm and some WIDE 225/45 (as wide as the EVOs 235), i have PLENTY of room to go to a 245 but my wheels stick out cause of the low offset. it isnt by much only a few mm but if your looking to SLAM you car; look at the higher offset and get some spacers to make it a 38-40mm offset
I currently have FN01R-C on my car, 17x8 with a +39 offset. They were shaved from a +35 to a +39. I am running on 235/40-17, not sure if I would want to put a 245 on my car, might stick out a little on the 8in rim, might even rub. But I am very happy with the 235. My gallery has a few pictures of the car with the bronze rims.
DaveT
92GSX
I too, am running 5Zigens. The +35 offset worked with my Hankook Ventus R-S2's in a 235/40. No rubbing even with my ghettofied camber adjusting up front.
Status
