1g with stoptech's what wheels will fit
You probably won't get a complete list of wheels. Stoptech has a template for checking clearances, so you might want to find out which wheels you like, which local shops have them in stock, go to the shop and check the wheel. If no local places have them, try calling up a place that does sell them and ask them to check. Good luck.
When I installed a Stoptech 4 piston 13” brake kit on a 91 Eclipse some time ago the wheel choices were somewhat limited if you do not want to resort to spacers.
The choices I found were Gram Lights 17x7.5 30 offset, SSR GT1 17x7.5 38mm offset, SSR Comps 17x7.5 38mm offset and OZ Superleggeras 17x8 40mm offset. Other choices which maybe heavier are available from Tirerack.
I chose the OZ Superleggeras which I have been very happy with.
