What type of nuts do i use for the turbo bolt?
Fabian972
264
Oct 18, 2005
Garland, Texas
I removed my heat shield to pb blast the turbo and o2 bolts and I notice that i have 2 of my turbo bolts missing. Inspect DSM before buying. Anyways ### kind of nut do I use for the turbo bolts? Help please !!! Can I use exhaust manifold nuts because i didn't find any turbo nuts on Slowboyracing website.
Turbo nuts??? They are just bolts that go down into the exhuast housing of the turbo from the exhaust manifold.
On the stock t25, there is 1 stud and 3 bolts. I would recommend just removing this stud and replacing it with a bolt.
EDIT: If you are getting ready for turbo removal, I would also PB blast the Downpipe bolts, the o2 sensor and the water lines on the turbo.
I didn't see thread on the turbo housing the 1st time checked agian with flash light saw it thanks o yeah pb the hell out of it i bought two cans of it.
who many washers do you use on the turbo bolts SB racing sells them single or in a set of eight how many do i need i thought only needed four. thanks diablo :thumb:
There are 2 on each bolt. (there were when I did my turbo swap)
Both go between the bolt head and the exhaust manifold.
    • george bromwell
    • pma1123
    • Sdcryan1
