What to log with MMCD on my 1g.
pwayzjellyroll
132
Aug 1, 2005
Piscataway, New Jersey
I FINALLY got a cable so I can log the info from my car and hopefully up my boost soon! Anyways, I'm trying to figure what exactly I should be logging. I tried searching but I couldn't find exactly what I was looking for, maybe I didn't search the right thing. Anyways I am using MMCd 1.8 I think I should be logging RPM/IDC/knock but what about timing advance/o2? Do I log 5 things or is something there not so important. My goals are only 15 lbs of boost so any info is appreciated.
I usually log RPM, Knock, Timing, O2s and TPS although TPS isn't as important as the others it helps to make sure the throttle is 100% open when the pedal is on the floor.
