What to do, need some advice...
teklein
107
Feb 18, 2004
Simpsonville, South Carolina
Ok, I have been very involved in Neons for about three years, thats why I bought an Eclipse with the 420A.
My Eclipse has 240000 miles on, but it runs very very well, looks it too. Except the rear main seal leaks a ton of oil.
So the motor has to be pulled. Here I have three options:
Take it to a shop, pay them and be done with it, or:
I have a cryo treated 2.0 block on my porch, already bored at .030 over, needs to be bored out to .040 (was a turbo motor that went south), so I put new internals in and off I go, or:
I also have a 1998 2.4 Stratus block, I can put new internals in it for next to nothing, and throw that in...
I just cant decide which one, I cant justify just putting a rear main seal in without putting a fresh block in at 240000 miles, it runs excellent, but it may be a time bomb. I dont know much about how it was taken care of, other than when I bought it had a new timing belt, tensioner, and water pump put in. And the care looks great for the amount of use it has had.
So what to do... And dont say buy a turbo eclipse - I love the Neon based 420A, I hate the 4G63, I owned one about four years ago and it crankwalked at 119000 miles....
A 2.4 swap is not easy. Doable yes but not easy. Some thing it's not worth it others think it's a great idea especially if yoiur going turbo as there is no replacement for displacement. My opinion would be just build your block that's cryo treated with some forged rods and H beams throw it back in and then worry about what you do turbo wise or w/e after that:thumb:
You also have the option of just removing the transmission, and installing a new seal.
i would just drop the tranny like loke said above and just replace the rear main seal.
You have a block with a shit load of miles on it your performance minded and you have a excuse to do it why not build it if you have the funds/means:confused:
Wouldn't it make sense to do both? Fix the seal in one day and then build an engine to put in later.
Am I missing something?
MB
Good point, didnt want to do anything twice :)
I was also unaware that I could pull the transmission only, in the Neons I always pulled the motor and trans together. One of the guys I know that did Neons as well said it was too much of a pain of a butt and took longer to just pull one, so I assumed that it was a pain on the Eclipse too.
Still at the 2.0/2.4 crossroads though... I have both motors, LOL. The cryo block needs a crank though.
Well, that's obvious also. I have a crank so send the cryo block to me and that leaves you with the 2.4. Problem solved.
No thanks necessary ROFL
MB
That part is obvious, but I own a restaurant so I have NO time, for the sake of time, it would be easier to have a motor built, then one night just swap it in real quick, LOL.
Im cheap :)
And I do have money, but restaurant owners do not have that MUCH money :) In fact, on average, unless you are a franchisor (which I will be soon), the profit from a restaurant is (roughly) ten percent on average. So even at 300,000 a year, only 30k profit :)
BTW, your salary is not included in the ten percent, its in the 90%, the ten percent is purely gravy :)
Im cheap :)
30K is a lot of gravy but any way take the block that's cryo treated build it pull the trans and engine out fix the seal and swap blocks and I know its' a stretch with money but I would invest in a good clutch because trust me later on when you get power hungry and start thinking hell I got a built engine why not boost or spray or both you will be like shit I have a stock clutch:notgood:. Good luck either way man.
Yeah, im leaning toward building a low compression 2.0 block.
Ill save the 2.4 for the Neon shell I have a line on :)
I would have bought another 95-99 Neon, but the deal I got on this Eclipse was crazy for the condition the interior, body, and everything was in. The rear main seal is the only thing wrong with it.
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
  • For sale 4G63 SPAL 6.5 inch Low Profile Fan - Push
    SPAL 6.5 inch Low Profile Fan - Push $55 + shipping & paypal fees* these are great to use with...
