What socket size are the spark plugs in the 420a?
That plug is stripped unless your not getting the socket on correctly. Should be 5/8.
should be 5/8 like garrett said, take a flash light and look to see if its stripped, if not you might have to push down the socket more, you are you a deep enough socket right?
That's what i was thinking, probably not all the way on the plug or the socket it self isn't long enough.
