What size? Vacuum Line
PFC_CiarlilloM
234
May 22, 2011
Euclid, Ohio
Okay, so I ordered RRE's Larson Silicone Hose Kit. I am in the process of doing a BLT and replacing all vacuum lines. I came across a vacuum hose where it seems that its between 4mm and 6mm. Can anyone tell me which size I should replace it with?
*Attached picture for location*
Thanks,
Mike
It appears to be 6mm because the hose seems bigger than the 4mm going into the throttle body/manifold. When I used the 6mm though there was a little bit of a leak.
