oil line what size
costas14
489
Mar 7, 2008
quincy, Massachusetts
95 gsx
oil line on the bottom is leaking from the oil pump, what size is the line and the screw that goes into that area, idk which line it is but its leaking from there, about a drop every 10 seconds so that would help so i can go pick it up
thanks
On a 95 GSX the only oil line that goes to the oil pump is the oil feed line. It is attached to the oil pump by a 12mm banjo bolt. I don't know the exact specs of it. I would suggest taking a better look to see where exactly the oil is dripping from. If it is from that bolt, it could be that one of the washers is failing or the banjo bolt itself has loosened itself with the vibration but that is nearly unheard of. If it is, take your tools and tighten them back up just make sure not to strip anything down there.
