What size turbo is this?
92awddsm
DSM Wiseman
4,877
93
Jan 17, 2004
Chesterfield, Virginia
I recently purchased a used full garrett setup but Im a little confused on the size of the compressor. I know its not what it is supposed to be but maybe someone can help me out. And before you start flaming me for buying something I dont know about, I paid less for the complete setup than I would have for the external wg alone. It is a t04 .60 ar. Inducer measures 2.125", exducer is 2.750". I tried to compare to other companies sizes but results were inconclusive. Can any garrett gurus look at the pics and tell me what Ive got? It has a turbonetics .63ar turbine housing with a standard t3 turbine but Im not sure of compressor size. Thanks in advance.
Thanks for the reply. Thats a little bigger than I expected but Im not going to complain. I guess I will be ordering a set of 750cc injectors next week to go with it.
Don't forget that the trim is just a ratio between the inducer and exducer. The compressor wheel on it is a bit smaller than the one on the SCM50 (aka the 50 trim). I doubt that it'll support over 400 flywheel horse. GSX4Life is right on when he states who knows what 60 trim LOL :D - Brian
Did you mic it with the comp housing off? It sounds like 62trim "V" Wheel, if not its pretty damn close.
Looks like it may be about equal to a 50trim 3" major wheel.
