What Kinda turbo is this?
There should be numbers in the squares. Post those.
Also, get us a closer pic. :) We need to see the compressor blades.
EDIT: Are you sure it's not: 49718-01740 instead of 71? If so, it's probably a 12A.
From the looks of the 3 port wastegate actuator I would have to guess a Starion/Conquest turbo...12a. Smaller than a 1g Auto turbo. Unless you own a starion/conquest it is basically useless.
Squigs
If you have never seen a starion/quest, then something else to consider is that turbo was made to sit on the top of the manifold, not hang below it like a dsm's.
Squigs
