What size injectors?!?!
Cyclone_90
84
Jan 26, 2005
Plainfield, Indiana
Hey guys I keep upgrading way past what my origonal plan was so now I have a 19c turbo and plan on running between 15-17psi. What injector size should I go with?? I also have the DSMlink. Thanks guys
Kurt
Well if you keep upgrading, and there's a chance you'll go with a larger turbo, get 660's. If not you're 100000% sure you will never get a larger one, get 550's. LOL. Good luck.
Well, If you plan on upgrading more, you could always step up to 850cc injectors. It really depends on how far you are going to mod your car. I just installed a scm5252 and running 750cc with no problems. I am also running 93 octane pump gas with 23-24psi. I think I will need more injector to run higher than 28psi(90%dc now) but Will you go this far? You need to figure your future plans or possible plans before you decide to purchase them.
Realistically, 650cc should carry you far with just a 19c. But once you go larger than 50trim or if you plan to run really high boost, 750 or better will serve you well.
