what size injectors for 16g
Depends on your boost level. You will be safe with a 190 or 255 fuel pump and stock injectors up to 16 psi. 18 psi plus I would go with a 255 or a 190, 650s and a SAFC to tune with.
I ran 23 lbs on a 255 fuel pump, charged air AFPR, fuel pump rewire, stock 450s, and SAFC w/0 knock & 32 degrees of timing. Its all possible with the tuning.
I would say go with a 190, 550s, & SAFC. If you want to be set for later on, get an AFPR.
Happy boosting.
Happy boosting.
Not calling BS on this or anything..but I'm assuming this wasn't on pump right?
Happy boosting.
How were you monitoring knock on a 2g???? And 32 degree's of timing under WOT and 23psi...your motor would have blown up.
I say.......190lph, 550, afpr and SAFC should be suffecient.
I plan on this same setup to use with a small 16g ported and clipped that im about to buy. The only difference is that i have a 255lph pump. :dsm:
