What size hose do I need for vacuum lines?
I believe it varies between 6mm, 8mm, and 10mm. Best bet is to take a small chunk of each of the old and have them size match it at an autoparts store. I think they use se sizes so that would be the easiest way to go about it.
I would stick with stock for vacuum lines. I tried the RRE hose kit and the hose they use looks nice but it slightly bigger than stock 1/8" vac line. They can leak a bit off your nipples even with zip ties on them. I got some vac line for cheaper at a parts store and it fixed my problem. The other lines which don't see boost pressure are ok though. Not worth the price overall.
I got the RRE kit in black but the silicone hoses are too large to put the stock clamps (things you pinch together) back on. Definitely feels like I could have used the money better somewhere else.
