What should i do to it?
Status
Not open for further replies.
jbray
Dec 17, 2005
Lancaster, Ohio
I am planning on buy a 95 Talon TSI AWD and with these current mods Eilbach pro-kit springs, Kyb adjustable shocks, Rm sway bar, upper strut bar, lower stress bar, poly motor mounts, powerstop cross-drilled rotors f&r, Hawk pads, rps 6 pluck clutch, short shifter, apexi down pipe, greddy exhaust, k&n FIPK, injen intake, Blitz turbo timer, Kosei 17" wheels W/ brand new tires, type s bov, momo shift knob, tripple gauge pod, boost, air fuel, egt, newer T/B, boost controller, i also have stock wheels, stock cd player, pioneer deck, stock intercooler pipeing, stock intake, stock clutch, stock bov, Evo 3 Big 16g Turbo, 31X6x3 front mount intercooler, hard short rought pipeing, ss oil feed line, 10-30w oil, full rear bushings kit............i was looking on some suggestions what to do next?
Since you don't even own the car as of yet, asking what to do next on it is inconsequential.
Next in my opinion, would be to buy the car. And my advice...when you do buy it, would be to do some preventative maintenance, get a good tune, and make sure everything runs and operates correctly.
+1
Then you need to decide what your goals are. Don't just come on here asking people what THEY think you should do next. It's your choice. Someone else's opinion of what you should do next might be something totally different than your goals. Is the car going to be a daily driver or a weekend car? Just do all the maintenance you can right now. Make sure the car is in near perfect running order before you do anything else. I will say that it sounds like you've got a good start though.
Status
