What should be 02 voltage be at idle
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
i have a cel p0170, from reading others threads looks like front 02 sensor,i have alogger, what should it be at idle,or do i have to drive it?
I didn't look at your profile, because I'm lazy but there could be a couple of things causing your problem.
p0170 is a CEL indicating maxed out FT's. If you are on the stock injectors is should be a bad front O2. At idle the O2 voltage should bounce around from about 0.20v to around 0.70v.
If you are on larger injectors you could just have a shitty lo-throttle tune.
Let us know. :thumb:
i have 550 cc injecotrs
What are your low throttle settings on the SAFC-II (assuming that's what you use to tune)?
What does your O2 voltage look like at idle?
low throttle setting is lo 4000 -17%
o2 bank 1 went from .12-.78 -1 to 3 % at idle
thanks
So the O2 voltage is bouncing back and forth the entire time at idle?
Take a look at your STFT & LTFT and let me know what they are.
correct.....STFT & LTFt what does that mean?
