What rpm are you activating your anitlag nitruos at??
turbo addict
482
Apr 17, 2005
Omaha, Nebraska
I would like to know what rpm you turbo 4g63s guys are activating your nitrous kit at? (with a window switch or dsmlink etc.) I am going to use this as an antilag and don't want kick it on too soon.
I have a built motor, and am thinking of a 75 or 100shot.
when are you turning it on and quick rundown of your setup and results.
Thanks!
When I ran nitrous on my EVO down the track I had it set to come on at 4k, which of course is lower than the car would ever see on the track. With the RWD using it to get on the converter, I have a 100 dry shot set to come on at 2500 rpm. That's a little lower than I would normally be comfortable with, but since I don't make any boost at all down there, cylinder pressure/torque is still very low.
thanks for your input.
I wanted to know if I should set the window switch for 3500 or 4000rpm, with either a 75 or 100 shot. I have a fairly large turbo. gt4276 with a 1.15 ar.
There is no 4276, perhaps you mean a 4294 or 4202. I run the 4294 with a 1.01 for reference. If this is a shifter car either of those two RPMs should work.
started of as a supra turbo. it is a pt turbo and has a 76.7mm inducer. instead of the 74mm inducer of the gt42102.
And thanks for the help. :)
