what part of the clutch system is this?
nlink720
Sep 11, 2004
frederick, Maryland
On the bottom of the 2G manual transmission is a dust cover, which when removed allows you to see the clutch fork, and more or less the throw out bearing.
In there, there is also some sort of metal clip that seems like it anchors the fork. It almost looks like a tripod, and clips into the metal side inside the opening.
Could someone tell me what that piece does?
I accidentally dislodged it, and when trying to re-insert it, bent the piece :toobad: ... it is about time for a new clutch and throwout bearing anyway, I guess.
Thanks
:dsm:
That clip holds the fork to the fulcrum (ball stud the fork pivots on) and manual warns against bending it. Get a new one and install when you do the clutch and throwout bearing. When removing fork you must slide it outwards (towards slave cylinder) to properly release this clip from the fulcrum (ie. do not pull fork up).
