What Kind of bulbs will i need for these
it uses the same bulbs that you use with the stock headlights but I know aftermarket lights are brighter and work better with that projector lense.
I bought what looks like the same projectors and no they did not use the stock bulbs. They did come with there own though. But your plug still goes into these lights, no modification other then the halo.
I have the same ones, H3 for the lows, and H3 for the highs. Should come with the bulbs already though
alright great im glad becuse i dont knwo too much about the headlight situation
The bulbs will either be H1's, H3's or some other H-variant, but usually H3's. When replacing them, I recommend replacing them with Silverstars.
As for the halo's, yes, wire them into the bumper corner lights. Be careful of the corner light connecters; on older cars, they tend to be corroded and falling apart. I had to replace my sockets with ones from a newer car from a junkyard. You can use quick splices, or you can use any other form of solder, splice, or connection you prefer, as long as the connection is tight and insulated.
    • george bromwell
    • pma1123
    • Sdcryan1
