What is this piece? Throttle body
jared_gibbs
113
Jun 16, 2010
Idaho Falls, Idaho
This piece just popped off while I was driving after boost. What is it? Just a plug? Any recommendations on what to use until I can get another one?
The Biss screw can be bought for under 20 dollars with the cap that you are pointing at. If you are looking to replace it, you can unscrew it and poke it through with a thin wire from the inside of the throttle body. Good luck
If you are starting to have issues with boost leak on the throttle body, just as well get the whole rebuild kit as they are only $50 because the shaft seals are probably already leaking and if not they will. Look in the classified on this site.
